Post by Detroitthunder87 on Apr 9, 2010 13:38:26 GMT -5
Ok! this may be a dumb question to some but i have to ask cuz im confused. On the 38mm stinger wastegate what do i do with the flange part thats not mouted to the stinger header? Do i run a dump tube to the stinger down pipe that i dont own yet? or do i just leave it open? Thanks !
Post by Stinger on Apr 9, 2010 15:24:56 GMT -5
As stated in the header ad on our site:
"Must use a braided flex section in external wastegate dump tube that routes wastegate back into downpipe".
Post by Detroitthunder87 on Apr 9, 2010 16:30:10 GMT -5
ok! I do plan on gettin the down pipe, but do you know where i can get the dump tube, or do i have to have one fabed up. Also does the flange suppose to be flush with the flnge on the wg cause the bolts dont seem like they are long enough. Sorry for the crazy ?'s but im not to familiar with this extenal WG stuff
Post by Stinger on Apr 9, 2010 18:19:01 GMT -5
You'll have to fab one up. We sell the 1.5" flex sections needed and you can get 1.5" tubing tons of places. You'll need one 90 degree bend at minimum and at most, a 90 and a 45. Not sure what you mean about the flange being flush and how that relates to bolt length.
Post by Detroitthunder87 on Apr 9, 2010 19:13:05 GMT -5
thanks stinger! what i mean is theres a ring in the middle of the flange that goes around the piston or valve of the wg, that creates a gap when connecting it to the header flange. I was just wondering if thats how supposed to be. as for the bolts I was just simply using the wrong ones. lol
Post by Stinger on Apr 10, 2010 14:09:58 GMT -5
The ring doesn't quite go flush with the flange, the gasket should fill the gap for the most part though.
Post by Detroitthunder87 on Apr 10, 2010 21:58:50 GMT -5
ok cool! thanks alot just making sure I was doing it right. if i run into anymore trouble ill be back for now i gotta hold on til i get this dump tube and stuff
