Post by onthetrailto on Aug 9, 2021 22:56:01 GMT -5
Hey all. Finally put my truck together enough to make a thread.
I've built several 2.3's for my truck, but this is my first turbo build. It is a little unorthodox, but I am stoked to get it running!
The block came from an early nineties ranger like mine and was cleaned up and bored .030 over. I have a stock crank with crower sportsman 5.7 rods and JE forged flat top Pistons.
I have a 60mm t3/t4 that came from a junkyard mustang and FMIC. I have Pimpxs and most of the goodies, but I have no plans for sequential for now.
I am in the process of getting it all together, but I am having some clearance issues with the AC and outlet from the turbo even with the flip kit.
I'm just going to say thanks in advance because I am going to have a NUMBER of questions.
I'd be happy to hear any questions or comments on the build!
Post by Stinger on Aug 11, 2021 1:28:58 GMT -5
Sounds like a fun build!
Be sure to dial the timing back significantly for the added compression with those flat top pistons, especially if premium fuel is 91 octane where you live.
Post by onthetrailto on Aug 12, 2021 23:01:44 GMT -5
Thank you! I have access to 93 here in Fl, but I am planning on keeping boost around 15. I am really excited, It's been a pipe dream of mine since my dad handed me the keys in 2012.
I still have a few kinks to work out,but I"m looking forward to hearing this motor sing!
Post by Stinger on Aug 13, 2021 19:34:04 GMT -5
You'll still need to turn the timing down some as it's set for 93 octane and stock turbo compression (8:1) rather than 9.2:1 or so like you should have now.
Post by onthetrailto on Aug 16, 2021 8:41:40 GMT -5
It will more than likely be even higher since I have an 8 plug head. I know they have a slight smaller combustion chamber.
Post by Stinger on Aug 16, 2021 13:27:46 GMT -5
Yeah, I believe that is correct. Dual plug ignition also requires significantly less advance. I've not tuned on them much but I've seen others reporting running significantly less total timing than a single plug head (like 10 deg vs 18 deg).
Post by onthetrailto on Aug 16, 2021 15:14:43 GMT -5
Would it be smart to start with more timing and then dial it back? I am reading a lot of material on it now, as timing as a concept is something I am not super familiar with. (Keep in mind I am still a good ways away from cranking this motor for the first time)
Post by Stinger on Aug 16, 2021 16:42:30 GMT -5
No, too little is better than too much as far as safety is concerned.
Post by onthetrailto on Aug 16, 2021 17:01:52 GMT -5
Good to know. It's obvious I have some more reading to do!
Thanks!
Post by onthetrailto on Apr 28, 2022 20:35:21 GMT -5
I've got a fairly mild tune that I'm pretty happy with (7 lbs of boost, decent torque). I am trying to get my A/C configured, and I haven't been able to find much info on getting it going.
Post by Stinger on Apr 29, 2022 10:42:25 GMT -5
Post your question in the PiMPx section and state what you're trying to figure out and we'll get it resolved. Be aware that a/c function is not computer controlled, only the wide open throttle shut-off (and sometimes the fan) is.
