Post by 93lxturbo on Apr 14, 2010 21:11:00 GMT -5
were can i get a adjustable clutch cable at for a 93 lx mustang.. or a part to fix the stock stuff..
Post by Matt Culpepper 2300gearjammer on Apr 14, 2010 22:13:34 GMT -5
What part is broken?
Post by 93lxturbo on Apr 14, 2010 22:24:00 GMT -5
nothing is really broke.. the teeth on the stock adjuster are just wore out..i have a new clutch cable in it but i do still need a clutch fork..
Post by Stinger on Apr 14, 2010 23:14:45 GMT -5
You can use all the 5.0 style firewall adjuster and the cable holder (can't think of the name of it at the moment) that goes on the pedal assembly, etc. on a 2.3 setup. You just have to use a 2.3 clutch cable so it will properly attach to the clutch fork in the bellhousing.
Post by merc460 on Apr 15, 2010 8:29:51 GMT -5
Post by phil88turbonotch on Jul 23, 2010 3:23:10 GMT -5
get a clutch quadrant (that's what it's called stinger) and firewall adjuster. you can also use the 5.0 cable but it requires getting a special clevis and modifying the hookup, not really worth the trouble. just get a 2.3 cable.
