Post by crouton23t on Jan 12, 2022 11:32:57 GMT -5
So I’m running into issues with my swap set up. I bought a square style intake manifold and one bolt on the head does not line up. Top hole on the water pump end of head. That’s problem number one. Two is that I would like to run the ranger serpentine belt and all. it seems like the block is not the same as the ranger Lima. So I could bolt up the 84 svo v belt water pump but the length of the water pump snout is not the same. Any info is helpful! Thanks
Post by Stinger on Jan 12, 2022 12:02:45 GMT -5
Any head that is old enough to originally come with an "inline" intake will be missing that one bolt hole. Drill and tap to fix that issue.
To run the Ranger front drive stuff, you have to run ALL of the Ranger front drive stuff, not just some of it. So if a belt touches it, it needs to come from the Ranger. This includes all pulley driven components, tensioners, pulleys, etc.
