Post by irsmart21 on Feb 11, 2022 15:38:35 GMT -5
Wanted to throw this out really quick to see if anyone has an answer. I am considering installing the CAS setup on my 84 SVO, but something caught my eye in the description of the item. It say it will not fit "Earlier Style" distributors. Does that mean the distributors with the 2 screw rotor button (which is what I have) vs the push on rotor button? If that is the case, is there any way, short of replacing the whole distributor, to get the CAS to work on my setup?
Post by Stinger on Feb 11, 2022 21:34:40 GMT -5
It works on the push on rotor style distributor. The easy solution would certainly be to just get a later style distributor and swap your gear onto it. I've not tried to modify the early style to work. Anything is possible with enough modification though.
