tinman
Post by tinman on May 16, 2010 13:39:07 GMT -5
in your faq section under which clutch for x power 350 to 450 hp. am i understanding correctly that a stock pressure plate and a 3 puck red disc is good for that kind of power?
Post by Stinger on May 16, 2010 23:06:52 GMT -5
It is, though those are flywheel hp numbers, not wheel hp. The 450 flywheel hp number is probably too high for a standard Mustang but with a light enough car it would hold. It won't last very long because the disc is so aggressive it wears a groove in the plate and flywheel.That disc (with red pressure plate) was in the bolt-on car when it went high 10's and is what's in my SVO (with red plate) right now because I had an extra one from bolt-on laying around. It's kind of a pain in the a** to drive on the street because it chatters so bad when getting moving from a stop.
