23tstang
guy on left(imports/v8) guy on right(2.3t power)
Post by 23tstang on Dec 8, 2008 15:15:26 GMT -5
hey i got a PK1 computer for 25$$ and i just now noticed that its different from the LA2 and was wondering if i can use it and if i can use it, does anyone know the repining. . .
thanks
tyler b.
Post by Stinger on Dec 8, 2008 15:35:17 GMT -5
You need to make sure you have the proper sized injectors and air meter to match that ecu. A PK1 is an 85-86 auto TC ecu as far as I can tell. That means 35lb injectors and small vam. The pinouts for your ecu, as well as the LA3 can be seen in the link below: rothfam.com/svo/reference/PEtoLA.pdfYou'll need to compare them and modify the wiring directions to match the PK1 pinouts. Listed below the 85-86 TC designation is the pinouts for your ecu (highlighted grey). Note to the right of those by two columns is the 87-88 TC (LA3) pinouts. By comparing these pinouts, you can see what differences there are and what changes need to be made to use the ecu you currently have.
23tstang
Post by 23tstang on Dec 8, 2008 18:58:37 GMT -5
thank you ;D
