Post by tutulate on Oct 22, 2022 22:05:18 GMT -5
Hi Shannon, My wife drove the SVO and liked it other than the loudness of the Bypass Valve's loud "whoosh" and "flutter" sounds. Can you suggest a way to silence the sounds? I am planning on connecting a hose to rout the valve to under the fender, but can you think of anything else I can try? I know you said it only connects pre-turbo with VAM/Maf systems, but would connecting it to the cold air under the fender pro-turbo create problems?
Thanks, Howard
Post by Stinger on Oct 23, 2022 10:30:44 GMT -5
Louder exhaust will fix the sound...just kidding...sort of.
You can connect it to the intake tube pre-turbo, it won't harm anything and should make it a little quieter as well.
Post by tutulate on Oct 23, 2022 16:03:27 GMT -5
Hmmm... I DO still have your "Muffler Delete" pipe on the shelf... I DID try turning up the music, but the Mrs did NOT go for that! Thanks, Shannon, I will go ahead with the pre-turbo mod!
