Post by bluebox460 on Jan 16, 2023 10:35:21 GMT -5
If you want to order the Accessory Pack but do not have an ECU version what version do you pick on the drop down menu?
Post by Stinger on Jan 16, 2023 12:02:44 GMT -5
It's impossible to order the correct pack without knowing ECU version. Is there no sticker on your ECU's connector?
First you need to know if it's an original PiMP or a PiMPx/PiMPxs. To determine this, look at the cable used to connect to the laptop, or the port those plug into. The original PiMP has a round connector on the ECU and the cable has a chrome end on the laptop side. The PiMPx/xs uses a square port on the ECU and the cable is all black.
Once you have this portion figured out, we can go over how to figure out what version number it is (it varies depending on if it's a PiMP or a PiMPx/xs).
If it's a PiMPxshift then it's easier because there are less versions (only two) and the difference is the size of the MAP nipple.
Post by bluebox460 on Jan 16, 2023 14:26:08 GMT -5
I was just asking so i could buy the accessory pack, to try to get the "full picture" of the install of the PiMPxshift. To see if it might be over my head.
Post by Stinger on Jan 16, 2023 23:18:38 GMT -5
It's never been over anyone's head (if they've been willing to ask questions here if questions arise, and if they don't quit as soon as they hit a bump in the road) so I'd say the odds are in your favor. I can send you a startup guide but some of the steps in there likely won't make sense unless you have the ECU in front of you (like the jumpers) or unless you have the software on your computer.
Post by bluebox460 on Jan 17, 2023 11:20:59 GMT -5
I have been on here a while and read a lot of threads. Jumpers, I have seen a lot about but other than putting them in the right spot don't seem to difficult. The monetary commitment is why I want to be sure. So yeah I will take a start up guide, from you.
Post by Stinger on Jan 17, 2023 11:57:21 GMT -5
Sent to the email you registered with on here. Check junkmail if you don't see it.
Post by bluebox460 on Jan 17, 2023 12:53:03 GMT -5
Got it, thank you!
