Post by bluebox460 on Feb 27, 2023 21:09:31 GMT -5
What size memory card would be recommended for on board ECU data logging? 32GB, 64GB, 128GB?
Post by Stinger on Feb 27, 2023 23:50:00 GMT -5
It sort of depends if you're going to be logging all the time, or have it configured to only log under certain conditions, or only when you press a button to start logging. A log is about 1mb every 5-10 minutes depending on how many things you're logging. So even a small SD card will hold a LOT of logging time.
