Post by longbedgts on May 2, 2023 22:14:51 GMT -5
Never done a breakdown thread, so here's the money pit. It's been an ongoing project for the past 15 or so years. It's got quite a few parts bought from Stinger starting back in 2008 when the mod bug bit me. They are dual exhaust kit, FMIC kit, 96# injectors, and PIMP ecu. Still using the stock 200K mile T5 with worn out syncros. Other mods and info:
-Esslinger ADI 2.5 Crankshaft with knife edge
-JE Turbo Pistons
-Total Seal rings
-Crower 5.5 Sportsman Rods
-1/4 Filled Turbo Block bored 0.030 over
-Esslinger Main Straps
-ARP Main Studs
-ARP head studs w/step washers(pn#200-8574)
-ARP Rod Bolts
-ARP flywheel bolts(pn#200-2802)
-Brass expansion plugs
-M127 Melling oil pump
-Esslinger billet aux shaft bronze dist gear
-Esslinger timing belt tensioner
-Esslinger star round tooth adjustable cam pulley/aux shaft pulley
-Goodyear Gatorback timing belt (pn#40210)
-Esslinger billet water pump
-Esslinger 6qt oil pan
-Aluminum head 2277 cam solid lifters big valves(1.890 int/1.590 exh)
-Speedway Motors aluminum thermostat housing
-Stant 180 deg thermostat (pn#13908)
-PRW aluminum valve cover
-Lokar adjustable dipstick (pn#1220174)
-Felpro 8993 headgasket
-Northern aluminum radiator(pn#380451)
-Derale dual fans+shroud (pn#DER-16833)
-65mm throttle body
-3G alternator
-electric powersteering pump from Volvo S40
-Walbro 255hp fuel pump
-96lb low impedance delphi injectors
-8an feed 6an return fuel lines
-Aeromotive adjustable regulator (pn#13129)
-meth injection
-PIMP ecu
-DIS ignition
-Spec stage 3+ clutch
-Aluminum driveshaft
-Chucks motor mounts
-Tial sport 38mm wastegate
-Tial Q 50mm blow off valve
-Wilwood adj prop valve
-Gnari exhaust manifold
-Turbonetics T3/T4 .63a/r
-FMIC w/2.5 piping
-3" downpipe 2.5" dual Magnaflows
Pics:
imgur.com/a/394NaU2
imgur.com/mZoDekU
-JE Turbo Pistons
-Total Seal rings
-ARP Main Studs
-ARP Rod Bolts
-65mm throttle body
-3G alternator
-meth injection
-PIMP ecu
-DIS ignition
-FMIC w/2.5 piping
Pics:
imgur.com/a/394NaU2
imgur.com/mZoDekU
