Post by merkurhardlyknower on Jun 11, 2023 19:49:46 GMT -5
Hello,
I am in the middle of a '86 Merkur to '87 Mustang swap, and I'm running into some difficulties.
Turning the engine on, occasionally it will stall immediately. When running, it sounds like a lawnmower and makes the car shake worse than I've ever seen a car shake, and eventually dies. I managed to get it to idle at 1.5k by adjusting how the distributor was clocked, but it still wants to die after a while. Naturally, I moved to check any codes I had, and got codes 81, 82, 83, and 84.
Doing some research, I found another post here where another guy had a similar problem and it turned out it was the ECU, so I pulled my LA2 processor out and opened it up to find nothing immediately unusual at all. No leaky capacitors, black spots on connectors, etc. I am not familiar with circuit boards so I cannot tell. Will post pictures on request. Earlier compression tests show that 1 and 3 definitely have compression, though 1 may have some sticky valve issues (engine measured 90-120-120-100 dry 95-?-?-150 wet) but I should at least be able to run it I imagine.
I suspect I have a timing issue of some kind. In attempt to diagnose the problem, I pulled spark plug wires and tried to start the car. It would not start if 2 or 4 were unplugged, but would continue to run exactly the same if 1 or 3 were unplugged. Frankly I don't know if my distributor is aligned correctly or if I even have my wires on right, at crank and cam TDC my rotor was pointing towards what was supposed to be 2, bottom left when viewed from driver fender. I simply put 1 there, then 3, 4, 2 in clockwise order. Otherwise, I have a good spark on all wires, tested by sticking a screwdriver in the wire, setting it close to a ground, and turning the car over.
In terms of things done, I have my car rewired to the tech article's specs for my year model, deleted EGR with a plate and removed solenoid, installed a gillis boost controller according to their instruction sheet, left knock sensor unplugged, and have a temporary hot air intake and no intercooler because I bought the wrong one from the junkyard (oops). In terms of things not done, I plan to install ACT sensor in EGR hole, not sure what to do with the sensor that plugs into the single wire with a 90 degree red connector, and no idea what that sensor is on the lower intake manifold with the half-moon shaped connector nor a plug for it.
I tried to cover everything, if more information is needed I will be happy to answer. Thank you!
