Post by jtech3181 on Jul 3, 2023 14:36:05 GMT -5
So I’m new to the 2.3 turbo world. I’m having some issues with finding the coolant hardline that runs from the water pump to the front port on the oil cooler. It is leaking due to corrosion. What are some options to replace this line? Just looking for some ideas that have worked for others. I’ve thought about just running AN line with fittings on each end, or just heater hose without the metal line? My concern with that is heat from the turbo as I am running a t3/t4 and it’s fairly close to the valve cover.
Thank you
Post by Stinger on Jul 4, 2023 1:50:41 GMT -5
Both of the options you mentioned are viable. If the heater hose option is at least 1/2" away from the turbo, it should be fine as it's being cooled internally. You can always wrap it with heat wrap or aluminum foil, etc. for extra insurance. You can use silicone hose instead of regular rubber heater hose if you want as well as it's rated for higher temps.
I've also seen someone fab the lines out of copper line/fittings soldered (like water lines in a house) and it actually created a pretty unique solution that was easy and affordable.
Post by jtech3181 on Jul 4, 2023 8:14:01 GMT -5
Ok thanks for the information, I may try the copper line way just for a cheap easy solution
