23newb
Boosting 15 psi
Post by 23newb on Sept 1, 2023 11:57:11 GMT -5
Haven't posted about this as it was low on the importance list, but after taking the steering column out to swap in the manual pedals the car doesnt start in the wrong position. Will say that the turbo coupe key cylinder was swapped out because who doesn't want a factory Ford Turbo key, but before the swap it worked just fine.
Turning the key to the start position the car does nothing, but while turning it back to the On position you have to find the sweet spot to get it to crank over. Is this a problem with the key cylinder or wiriing?
Post by Stinger on Sept 1, 2023 15:47:31 GMT -5
I'd assume it's a cyl issue simply because it worked prior to swapping and I can't think of a way a wiring issue would manifest this way.
23newb
Boosting 15 psi
Post by 23newb on Sept 1, 2023 16:54:06 GMT -5
Will play with the Mustang and Turbo Coupe cylinders to see whats up - thanks
