Post by cjdavid on Jun 10, 2010 21:10:55 GMT -5
I have gotten back to work on this '86 Mustang. It was a carbed 4 cyl. I pulled the tank today hoping to change the pump to the one I pulled from the TC and as suspected it's totally different. My question is will a tank from a fuel injected 4 cyl work? Or do I need to find an 8 cyl fuelie tank? Also, my son has a '99 Lightning and has put bigger pumps in his tank, does anyone know if one of his pumps is bigger than the stock TC pump? And would it hurt the stock injectors until I upgrade to 55lbr's? Sorry for the long post and any mispelling..4:30 am was a long time ago now. Thanks for any info.
Post by Stinger on Jun 10, 2010 23:23:38 GMT -5
You can use any 87-93 EFI mustang fuel tank. I would assume the stock lightning pump is quite large but you'd have to google to verify. The injectors don't care what pump you run.
Post by cjdavid on Jun 11, 2010 5:36:19 GMT -5
Hey Stinger, I want to thank you for your quick replies. Your dedication to your site is top drawer! Thanks for the info.
Post by merc460 on Jun 11, 2010 9:16:54 GMT -5
Just remember to swap our fuel level sender to the 87-93 tank, early mustangs use a different ohm scale than 87 and up mustangs. I found this out the hardway.
Post by cjdavid on Jun 11, 2010 11:42:09 GMT -5
I have located a tank with sender from a v6 car to use. with the harness.
Post by cjdavid on Jun 29, 2010 13:34:33 GMT -5
Does anyone know if the v6 harness will splice right into the old 4cyl harness. it's the one that goes through the trunk floor, and work the fuel gauge?
Post by Stinger on Jun 29, 2010 15:01:09 GMT -5
I would assume all of the chassis wiring is the same.
Post by jimmy86mustang on Jun 29, 2010 16:42:07 GMT -5
I cheated when I did mine. Instead of replacing the entire harness for the sender and fuel pump, I just added the wiring for the electric fuel pump. I left the fuel gauge sender harness alone, and it plugged right into the sender on the 86 GT tank. I stripped the fuel pump plug and about 3ft of wiring from the old TC tank harness. Then I poked a hole in the Mustang's molded rubber plug where the sender wires went through the floor, and fished the fuel pump wiring through the hole. It's insulated by the plug so it won't rub against anything, and the sender wiring is still untouched.
