Post by birdman on Jun 13, 2010 22:25:16 GMT -5
can anyone tell me if the low oil level sensor on the oil pan can be removed and plugged without removing the pan. mine leaks.thanks.
Post by phil88turbonotch on Sept 7, 2010 14:45:39 GMT -5
it screws into the pan so i would imagine if you find the thread size you could get a plug that will work. i just switched to the stock N/A pan. no hole
