Post by mthibbitts on Nov 16, 2023 19:52:55 GMT -5
Hi all,
Finally got my crawler dynoed.
It does have a C4 Auto, Atlas 4 speed transfer case and a GM 14 bolt one ton axle so there is probably about 35-45% drivetrain loss.
It put down 135hp to the wheels with a max boost of 14 psi and only 12 degrees of total timing. It's as much timing he could add without severe detonation. Intake temps were reasonable and I have the coldest copper spark plug I can put in this head. Its 12mm motorcycle spark plugs.
Specs:
- Stock turbo block with CP turbo pistons.
- Essinlger SVO Aluminum head
- About 64.5 CC
- Esslinger EFI intake adapter
- BoPort 2.1 cam
- 255 Walbro pump
- Billet fuel rail and adjustable fuel regulator
- Air to water intercooler
- Stock injectors
- Stock IHI turbo
Engine runs good with no mechanical issues and ignition/cam timing is correct. Compression ratio should be very close to stock. The only thing my tuner suggested to be the cause of the detonation is that the turbo is so restrictive its causing backpressure. I know people have put the Esslinger head on all the time, but I am sure they have never kept the stock IHI turbo. Thoughts?
Also, my stock injectors are maxed out and could not keep up at 6000 rpms. I thought those could handle 250 hp? Maybe the EFI intake adapter is the cause of this issue? It pushes the injectors farther away from the head and maybe atomization isn't as good hence why they are maxed out?
With that said, what is a good turbo you recommend for this set up? T3/T4? Looking for a quick spool up since I rock crawl this and it won't see the strip. Needs to flow good too. Would like to run 20lbs of boost or so.
Also, what size injectors would you recommend I step up to?
Does anyone know what the stock stall is on a Turbocoupe with an auto? I have a stock Pinto TC and I believe it's about 1600 stall which is too low (was told it was 2200 when I bought it). The engine wants to stall occasionally when I nuts it from park to reverse or drive. This started after I put the new cam in so I am sure it exasperated the condition. I was thinking a stall of around 2500-2800?
Thanks in advance!
Specs:
- About 64.5 CC
- BoPort 2.1 cam
- 255 Walbro pump
- Stock injectors
- Stock IHI turbo
Thanks in advance!
