black
Post by black on Jun 18, 2010 15:11:01 GMT -5
I am referring to the three fittings (2 coolant lines) and the one that runs to the sensor on the backside of the valve cover right in the middle of the turbo.
I have soaked them nicely with penetrant but can't seem to find the right size wrench to remove them. Everything I have tried starts to round the fitting and I don't feel like damaging them. What's the best way to get them off?
DRD
Boosting 10 psi
Post by DRD on Jun 18, 2010 23:43:51 GMT -5
use a flare nut wrench.
black
Post by black on Aug 10, 2010 17:27:31 GMT -5
I have soaked these things in PB blaster and am using flare nut wrenches with no luck. Can't even get them to budge. Just keep rounding the nut. Is there a trick to getting these off???
88bluebird
88 thunderbird TC
Post by 88bluebird on Aug 10, 2010 17:41:13 GMT -5
I had to use a pair of vise grips to get the fittings out and replace the lines
Post by Stinger on Aug 10, 2010 22:23:41 GMT -5
Heat until glowing orange, then remove.
black
Post by black on Aug 11, 2010 9:05:35 GMT -5
they are just standard threads not reversed correct?
88bluebird
88 thunderbird TC
Post by 88bluebird on Aug 11, 2010 13:18:28 GMT -5
Righty tighty... Lefty Lucy ;D
