Post by tiresmoke69 on Jun 29, 2010 21:58:03 GMT -5
I had the dist. gear strip out along with the dist. drive shaft gear last week. Since I knew there was metal shavings in the oil pan now, I decided to pull the motor and do a much needed clean up/ replace every gasket sort of deal. Well I have made some progress over the weekend and took pictures along the way. Here are some pictures starting from when the motor was still in the car until now.
I hope to have the car up and running again by the end of july. There is much more cleaning up of the engine bay, wiring harness, and other engine parts to come. The color is Ford Yellow.
