stackz
alive and kickin
Post by stackz on Sept 7, 2024 11:11:54 GMT -5
On the pimpx shift, can you use low impedance injectors or only high impedance? Will be going in a 95 mustang gt auto if that matters
Post by Stinger on Sept 7, 2024 13:44:36 GMT -5
stackz
alive and kickin
Post by stackz on Sept 7, 2024 14:01:04 GMT -5
yeah thats what I realized after posting it. I guess I can always just wire in a resistor box. I'm almost ready to drop coin on the pimpx shift. just answering the last couple questions I have for myself. thanks!
Post by Stinger on Sept 7, 2024 14:16:32 GMT -5
You could do that. Hopefully the injectors you have are a quality injector and not a propane or natural gas injector being used for gas (this is what most of the cheap low z injectors over 100 lb/hr are).
stackz
alive and kickin
Post by stackz on Sept 7, 2024 14:31:41 GMT -5
no, they are actually trick flow low-z 72lb injectors that came with the edelbrock performer rpm intake I got off fb market a couple months ago for a screaming deal. since I already have them I figure, why not try to use them.
stackz
alive and kickin
Post by stackz on Sept 7, 2024 18:18:56 GMT -5
You could do that. Hopefully the injectors you have are a quality injector and not a propane or natural gas injector being used for gas (this is what most of the cheap low z injectors over 100 lb/hr are). I guess my other question is about the trans controller. Is it pre programmed for the shift points or are there different files for the different trans options? Basically I have the stock aode right now but plan to swap to an explorer 4r70w when it finally blows and they have different shift points so I know that will need addressing eventually. How would that work?
Post by Stinger on Sept 7, 2024 20:43:15 GMT -5
You tune trans behavior like you tune the engine. You adjust up-shift points, line pressure, lockup points, downshift points, WOT shift RPM, etc. for each gear.
stackz
alive and kickin
Post by stackz on Sept 8, 2024 7:07:26 GMT -5
You tune trans behavior like you tune the engine. You adjust up-shift points, line pressure, lockup points, downshift points, WOT shift RPM, etc. for each gear. interesting. I wonder if there is anything online about what the stock shift points and such actually are? I'd prefer to just set it to whatever factory is and forget it.
Post by Stinger on Sept 9, 2024 13:08:44 GMT -5
Not likely.
