Post by brycad1ds on Nov 3, 2010 9:28:00 GMT -5
;DProject finally underway! ;D
I have complete 88 TC 2.3L turbo, 8.8 Disc rearend, and TC LA3 Computer. I also went and got a GT spoiler too. Just like it better.
I will post more as things come together. I have waited a year and a half to start this. All of my friends think I am crazy.
The typical comment is why not just put a V8 in it.
My response is why? Anyone can make a V8 go fast, I want an SVO!
Post by Stinger on Nov 3, 2010 13:13:57 GMT -5
Sounds like fun...
Post by brycad1ds on Nov 6, 2010 19:02:48 GMT -5
Thanks man.
I found your website two years ago and have just been itching to get started. I will have orders coming your way as I get things moving. I want to put the dual exhaust on and some of your other cool accessories. I know for sure that I want to continue to use it as my daily driver. So I don't know how much I will really Mod. But we will see as I go along.
Post by Stinger on Nov 6, 2010 23:14:58 GMT -5
That's what they all say...
Post by brycad1ds on Nov 8, 2010 23:26:20 GMT -5
LOL, I am sure they do.
Post by bobbarker on Nov 10, 2010 10:56:34 GMT -5
haha! Stinger feels used.
Post by boostgobbler on Nov 14, 2010 23:06:13 GMT -5
DUDE! We all hear the same crap. You should have seen/heard some of the crap i had to deal with. I see your from MD me too! maybe when you get that thing running we can cruise.
jaidedeye
Boosting 15 psi
Big Turbo SVO
Post by jaidedeye on Nov 21, 2010 0:26:46 GMT -5
some of the mustang forums i am on have no respect for 2.3 turbo mustangs at all...funny part is i called out the v8 guys on FEP for a race (road course or drag) race and didnt hear a peep....
Post by brycad1ds on May 3, 2011 13:11:22 GMT -5
This sucks, I have run into a snag. My car has stopped running suddenly. In this case it cranks real good but will not fire. I have check the fuel pump, relays, inertia switch, plugs and wires. I have also done a code read and am getting no codes. fuel pressure is good also. unsure about spark. but was told that if the CSPS is bad it wont get spark. I am now checking the crankshaft position sensor as a next step. I cant wait to pull this motor. I am almost done with the 88 rebuild. If anyone has any suggestion on my sudden issue your assistance would be appreciated. Boostgobbler, where in Maryland do you live, I am in southern Maryland, In La Plata.
Post by brycad1ds on May 3, 2011 13:14:45 GMT -5
I have been getting the same grief from all my 5.0 and V8 friends. They all want me to change my mind and swap in a big block. No respect for the turbo 4 Cyl. They just don't get how much fun the 2.3L is.
Post by Stinger on May 3, 2011 17:51:48 GMT -5
This sucks, I have run into a snag. My car has stopped running suddenly. In this case it cranks real good but will not fire. I have check the fuel pump, relays, inertia switch, plugs and wires. I have also done a code read and am getting no codes. fuel pressure is good also. unsure about spark. but was told that if the CSPS is bad it wont get spark. I am now checking the crankshaft position sensor as a next step. I cant wait to pull this motor. I am almost done with the 88 rebuild. If anyone has any suggestion on my sudden issue your assistance would be appreciated. Boostgobbler, where in Maryland do you live, I am in southern Maryland, In La Plata. You need air, fuel, and spark (at the right time) to run. You know you have air so you need to verify whether you have spark and fuel pressure before any more info can be provided.
Post by brycad1ds on Jul 14, 2011 22:55:05 GMT -5
Finally found and fix the problem, It was the crankshaft position sensor. Got a new one, put on and the car is running good.
Post by brycad1ds on Jul 14, 2011 22:57:20 GMT -5
I think my DIS module is going bad now. I am having lower acceleration and seem to be going thru more fuel then I should. Its a never ending story.
Post by bobbarker on Jul 14, 2011 22:59:04 GMT -5
From what I've learned these all cars are a never ending story!
Post by immloki on Jul 21, 2011 18:59:25 GMT -5
Thats anything with a pony emblem. People just can't stay away from modding a stang.
