Post by turbopony92 on Nov 22, 2010 12:38:57 GMT -5
Ok I have a couple of questions. I have a stinger oil feed line that I ordered a while ago for the stock placement and I was wondering if it is long enough for a center mount header too? Also what size is the holset one? Or is it the same and just has adapter fittings? One more question about the drain line, what size is the center mount one? I saw some posts about you wanting to do -10 for a stock placement line, is the center mount one a -10 or is it smaller?
Post by Stinger on Nov 22, 2010 16:00:09 GMT -5
Center mount and stock location feeds are the same length. Holset length is the same length with a 90 degree adapter and longer with the straight adapter. Both return lines are now -10 size.
Post by turbopony92 on Nov 23, 2010 1:59:56 GMT -5
Thanks alot!!
