Post by frankd2054 on Feb 28, 2011 0:00:09 GMT -5
i have a 93 mustang swapped to the 2.3t upgrades are as follows gutted intakes ported head ranger cam and double spring valve springs diamond pistons crower rods eagle crank high flow oil pump high flow water pump holset turbo tube header 3in down pipe and mid pipe fmic la3 comp 255 walbo pump round tooth timing set msd ignition set and 8.5mm wires theres more but i cant rember at this time my problem is I'm not getting enuff fuel and i want to swap it to mass air and find a good way to tune the car also I'm looking to get a lill more power the car will pop at around 25 pis of boost what are the ways of sapping to mass air and what injectors do i need also what do i need to tune the car all said and done thanks for the help
Post by Stinger on Feb 28, 2011 3:10:22 GMT -5
Looks like you found the PIMP thread and may have answered your own question.
Post by frankd2054 on Feb 28, 2011 12:51:36 GMT -5
yeah i found that and read thro it then kinda luaghted at myself what is the best head gasket to use, i tryed useing the comtic but it started leaking really bad soo i am aout to try the fel pro hp one good or bad?
Post by Stinger on Feb 28, 2011 14:37:06 GMT -5
If your deck and head is flat (within .002") then there is no reason a Felpro 8993 (stock replacement) gasket won't do the job. This is what I run in my SVO and people have made over 500rwhp with them.
If your deck isn't flat (mine wasn't before I machined it), no headgasket will hold.
This is all assuming you're applying proper torque to the headbolts.
Post by frankd2054 on Feb 28, 2011 16:10:12 GMT -5
the head and the block have both been decked flat. i was planeing on useing a fel pro Q1035 gasket
Post by Stinger on Feb 28, 2011 23:51:00 GMT -5
I'd save the extra $50 it will cost you and just get an 8993 and fix the tune instead. With a flat deck and proper headbolt torque, the only things that will blow a headgasket is going lean or having too much timing.
Post by frankd2054 on Mar 1, 2011 0:26:31 GMT -5
at the end i had it retuned with low boost but i want to run around 25psi at the track and the timeing was all good at 18 to 20psi the car was good and ran a 13.2 run after run but like everyone i want to go faster and need a new way to tune the car and make it faster witch i hope the pimp ecu will help and also a esslinger cam will too ;D
Post by Stinger on Mar 1, 2011 1:21:03 GMT -5
Pimp ecu and Bo-port cam you mean
Post by frankd2054 on Mar 1, 2011 14:58:16 GMT -5
never heard of the bo-port cam. do you have a link to look at it?
Post by Stinger on Mar 1, 2011 15:06:10 GMT -5
Post by frankd2054 on Mar 1, 2011 15:20:05 GMT -5
haha o ok that simple
Post by denz on Mar 1, 2011 21:30:27 GMT -5
Sounds like u got help. Or you got pimped! Im not sure.
