radguy
Boosting 15 psi
Post by radguy on Aug 5, 2011 0:54:23 GMT -5
This pains me but my daughter is having surgery on Sept 1 so I need some extra cash. Lets see if there is enough interest in parts to make it worth my while to part the car.
Boport Stage 1 D-Port with 2.5 cam. This head was assembled as a bolt on package from Bo. Also comes with ARP head studs. I have put ~200 miles on it. $1100
Kirban AFPR (~200 miles) $55
Custom upper 120 degree rotated (0 miles) $150
65mm TB (~20 miles) $50
Walbro GSS340 (installed in tank but never ran) $75
Tial MV-S 38mm v-band gate (new but installed) $200 (has all of the springs)
Stinger crossover pipe 3" $75
Wilson MSII V3 (launch control, shift light, fan control), 4 LS2 coils, mounting bracket, TFI, reluctor and wiring harness for coils $750
SVO valve cover $50
Good turbo short block (~40K miles) $300
Good turbo short block (~70K miles) $300
Turbo short block with two bent rods (~120k miles) $100
Bare short block $50
Stock flywheel, ClutchNet 4 puck clutch disc, 1900lb pressure plate (~100 miles) $200
Good T5 $150
T5 needs syncros $50
Large NPR $150
Greddy type R BOV $200
Dan
Post by bobbarker on Aug 5, 2011 10:44:14 GMT -5
I want the injectors!!! Have money now!
Post by bobbarker on Aug 5, 2011 10:45:46 GMT -5
And what's a stinger cross over pipe? And where are you located? If close I might want one of the short blocks.
radguy
Boosting 15 psi
Post by radguy on Aug 5, 2011 13:06:01 GMT -5
Bobbarker I am located in Dover Ar. I should have said Stinger 3" mid pipe.
Dan
Post by bobbarker on Aug 5, 2011 15:58:44 GMT -5
Gotcha. If I were closer I'd want one of the short blocks. Too much to ship to FL. You want to sell me those injectors?
radguy
Boosting 15 psi
Post by radguy on Aug 5, 2011 19:27:34 GMT -5
Bobbarker you have a PM.
Dan
Post by fordtech86 on Aug 8, 2011 14:27:39 GMT -5
Do you have pics of the intakes and turbo?
radguy
Boosting 15 psi
Post by radguy on Aug 8, 2011 15:16:41 GMT -5
Post by bobbarker on Aug 9, 2011 3:07:44 GMT -5
Showing a bad link to the Flickr.
Post by 45vaquero on Aug 10, 2011 18:09:36 GMT -5
Is the t-body a direct fit for a 2.3 upper?
radguy
Boosting 15 psi
Post by radguy on Aug 10, 2011 19:49:04 GMT -5
Honestly I don't know. I redrilled the holes to fit this intake. I think it is a stock 2.3 pattern.
Dan
Post by 82te72 on Aug 27, 2011 23:15:22 GMT -5
would you sell just the MS unit by itself without the coils and mounting bracket and anything else?
Post by stangfrk23 on Sept 3, 2011 12:04:48 GMT -5
Do you still have the rotated upper?
Post by jeremy23t on Sept 4, 2011 17:45:31 GMT -5
still got the 120 upper?
email me lowrider_crew_04@yahoo.com
