Post by midnite855svo on Sept 22, 2011 4:36:54 GMT -5
are you guys mounting it to anything with the included brackets and nuts, or just leaving it connected to the hoses and sitting freely?
ccm302
86 SVO
Post by ccm302 on Sept 22, 2011 13:20:49 GMT -5
Just leaving it connected and sitting freely. The lower portion of the front bumper does a fine job of holding it in place.
Post by midnite855svo on Sept 22, 2011 13:33:49 GMT -5
thanks! did you remove the brackets for the AC condenser or just leave them in there? That article posted last page says he removed them but Im not so sure how they come off lol
ccm302
86 SVO
Post by ccm302 on Sept 22, 2011 13:39:37 GMT -5
I took them off. On my particular car, it would've taken more bending of the oil cooler line than I was comfortable doing to make it all fit. I'm at work right now but I'll try to remember to look and see how I got them off. Stinger may be able to answer quicker.
Post by Stinger on Sept 22, 2011 14:54:08 GMT -5
The condensor brackets are bolted on so they are easy to remove.
Post by midnite855svo on Sept 22, 2011 14:59:03 GMT -5
oh i guess i will have to look harder to find the bolts, thanks!
Post by midnite855svo on Sept 23, 2011 2:02:45 GMT -5
havent turned the car on as I need a vacuum fitting to hook up the bypass, but i think that bypass setup should work at least for now! I think I want to replace the power steering cooler lines, I dont like how they push back agaisnt the intercooler, what are you guys using for a replacement, just a simple one like this? www.summitracing.com/parts/DER-13200/
