Post by 45vaquero on Oct 25, 2011 17:32:01 GMT -5
I can't remove the alum. housing, but I can spin in completely freely and the impeller wheel dosen't move. I'm guessing it kaput, so i'm ordering a t3/t4 w/stage 3 wheel, 50 trim. what is the different a/r mean? also, was my header kit supposed to come with the turbo return oil manifold? Thanks alot
Post by Stinger on Oct 26, 2011 14:52:25 GMT -5
The a/r decides what rpm it spools at...trades top end flow for quicker spool. .48 or .63 is what you'd be looking at. I like the .63.
You mean the aluminum return flange that bolts to the turbo? If so yes, it should...I thought I screwed one onto the line but I may not have. Does the line have a plastic cap over the threads on both ends?
Post by 45vaquero on Oct 26, 2011 16:20:23 GMT -5
The large line had 2 45's attatch to the hose fittings. the hose has a straight on one end & a 90 on the other. I don't think either had plastic caps though. Does the 90 end go to the turbo? w/o the turbo that appears to be the best fit. What is the best way to cap the metal water feed line?
Post by Stinger on Oct 26, 2011 16:27:16 GMT -5
Hmm, sounds like you didn't get a flange in the box...figures we'd miss something when we were throwing parts in. PM your address and I'll mail you one unless you're going to be in my area before you'll need the flange.
Yes, the 90 threads into the turbo, the T goes into the head.
You can get a water cooled turbo to keep the water lines in use. Otherwise they make "bypass hose" blockoff caps that you can clamp onto the line.
Post by 45vaquero on Oct 28, 2011 20:30:33 GMT -5
I tested my wastegate. I don't know what the spring inside looks like, but the extra spring had yellow stripes. The waste gate crack was 9.80psi. As I understand it, that means and 18 psi spring + or -.
Is there a gasket in the wastegate I need if I swap springs to test the other spring? What are the + & - of "recycling" the wastegate dump?
Post by Stinger on Oct 29, 2011 0:30:02 GMT -5
No gasket, just make sure the internal seal is seated and doesn't get pinched when reassembling it.
Not using a wastegate dump means the wastegate will vibrate like crazy at certain rpm's, causing cracks to try to form around the wastegate tube. I've added an additional brace to this area to help prevent it.
The other issue is it's pretty loud when it opens (it's a 1.5" exhaust leak) and it puts black soot below the gate. This sound also makes it hard to hear detonation because it's got a similar sound and comes in at the same time as detonation would.
Post by 45vaquero on Oct 29, 2011 12:35:31 GMT -5
The w/g crack psi on the yellow stripe spring is 4.9, green stripe 9.8.
Are there 2 different oil return line lengths? Mine looks to be a few inches short. Oal from c/l of the 90 to the strt flange is 12". If I can get it to fit, it will be tight to the #4 header tube.
Post by Stinger on Oct 29, 2011 20:01:14 GMT -5
Sounds like the yellow one is the "low boost" spring then.
There is only one header return line. It's the right length. A pic of how it's supposed to be routed is in the FAQ section of this forum...it never goes anywhere near the #4 header tube.
Post by 45vaquero on Oct 29, 2011 21:43:15 GMT -5
So I need to rotate the centersection 90 deg. also?
Post by Stinger on Oct 29, 2011 23:20:05 GMT -5
The oil gravity feeds out of the turbo so the return always has to be pointing down.
Post by ascentpro on Oct 30, 2011 5:06:22 GMT -5
Could you custom make one of your top mount headers with a volvo flange for the volvo head swap?
Post by Stinger on Oct 30, 2011 16:10:46 GMT -5
No, but I've seen a few others do it so I know at least the header tube spacing is close enough to make it work.
Post by 45vaquero on Nov 9, 2011 20:27:03 GMT -5
Will a Holset HE351CW fit the stinger header?
Post by Stinger on Nov 9, 2011 23:37:35 GMT -5
Yes, though you may need a spacer where it bolts to the header depending on where you rotate the compressor housing to.
Post by real merkur 87 on Mar 10, 2012 23:39:02 GMT -5
is this like the header thats on ebay or is it different? Whats different about? Is it any thing like the from bo-port racing? Thanks!
