Pistons
Oct 28, 2011 17:54:39 GMT -5
Post by Carl on Oct 28, 2011 17:54:39 GMT -5
Another question, I have been given the recommendation to get the pistons and rods balanced. The spec sheet from CP says the rods are +/- 1 gram. How are stock rods usually? Balanced or way off, should I spend the money to get them balanced?
Pistons
Oct 29, 2011 0:31:24 GMT -5
Post by Stinger on Oct 29, 2011 0:31:24 GMT -5
Unless this is an 8000 rpm race engine, don't bother. As a brake college student, I once ran two Speed Pro and two stock pistons in the same engine...it was fine for over 30k miles before I sold the car.
Pistons
Oct 29, 2011 12:42:27 GMT -5
Post by Carl on Oct 29, 2011 12:42:27 GMT -5
Anything to save money! Thanks Shannon.
Post by Carl on Nov 4, 2011 0:19:48 GMT -5
I noticed the the #1 rod got hot at some point in it's life. It is blue'd on the big end. Think they will be ok to run or should I pick up a new set of rods? If they are ok, I can't remember which side the oil squirter hole faces....left or right?
Post by Stinger on Nov 4, 2011 2:19:47 GMT -5
I wouldn't run a blue rod.
Pistons
Nov 4, 2011 20:39:42 GMT -5
Post by Carl on Nov 4, 2011 20:39:42 GMT -5
Well hell, this budget build went right out the window.
