Post by Carl on Oct 2, 2011 1:33:58 GMT -5
What is the current wait time for either .010 or .020 over pistons? As you saw on TF, I'm in need of new slugs. Thanks in advance.
Pistons
Oct 2, 2011 22:18:10 GMT -5
Post by Stinger on Oct 2, 2011 22:18:10 GMT -5
Both of those sizes are a few weeks out. There is only one set of .030 available right now.
Pistons
Oct 2, 2011 23:00:16 GMT -5
Post by Carl on Oct 2, 2011 23:00:16 GMT -5
Sounds good.. I'll be ordering this week. I definitely don't want to bore it out that far...
Post by Stinger on Oct 3, 2011 0:01:37 GMT -5
Sounds good. The earlier the better so we can make sure CP has them ready for us as scheduled.
Pistons
Oct 3, 2011 11:11:38 GMT -5
Post by Carl on Oct 3, 2011 11:11:38 GMT -5
Well then, order placed for the .020's! Thanks Shannon!
Pistons
Oct 3, 2011 16:30:39 GMT -5
Post by Carl on Oct 3, 2011 16:30:39 GMT -5
Here's another question, my local machine shop will not bore my block without the pistons on hand. I have read what it says on your site and CP's, is it a huge deal if he does have them instead of just cutting a hole like it says on the site? The next closest machine shop is at least an hour away.
Pistons
Oct 3, 2011 22:04:37 GMT -5
Post by Stinger on Oct 3, 2011 22:04:37 GMT -5
That's up to you to decide. I don't trust a guy at a machine shop to know more about the ideal bore for a piston size than the piston manufacturer does, nor do I trust his ability to measure them more accurately than CP. Pistons also "grow" when you hold them in your hands and they warm up (which is ofter where machine shop guys measuring them get into trouble). If they follow the instructions in the piston box that pertains to final bore size and don't try to adjust it because they "know better", it's fine...of course the info in the box is the same info they have without having the pistons in hand so if they planned to do that, they wouldn't insist on having the pistons in their hands
Pistons
Oct 3, 2011 22:22:58 GMT -5
Post by Carl on Oct 3, 2011 22:22:58 GMT -5
That's my issue, I know there are a bunch of drag racing guys that have his engines. I think he will do a good job, just don't like that he has to have the pistons before he bores the block.
I guess I will call around Boise tomorrow and see if anyone up there will do the work with the printed specs only.
Post by Stinger on Oct 4, 2011 1:27:38 GMT -5
Seems like they'd understand if you tell them they are a "custom order" piston and you won't have them for a while so you want to have the block ready for them when the pistons arrive...
Pistons
Oct 4, 2011 10:19:39 GMT -5
Post by miles84 on Oct 4, 2011 10:19:39 GMT -5
I have learned never to "assume" that something is what a piece of paper says it is. I've had pistons that measured different from the rest, valves that weren't true, cranks that weren't ground right, bearings that were oversized. Unless you have the part in your hand to measure, dont go by whats on paper. Just my .02. And this was learned the hard way
Pistons
Oct 7, 2011 20:17:03 GMT -5
Post by oneowner88lx on Oct 7, 2011 20:17:03 GMT -5
Very common for machine shops to want the pistons in hand before boring. That is not a bad thing.
Pistons
Oct 12, 2011 22:44:10 GMT -5
Post by Carl on Oct 12, 2011 22:44:10 GMT -5
AWESOME!!! Showed up today, why do the really pretty parts have to be hidden in the block!?
Pistons
Oct 12, 2011 23:42:50 GMT -5
Post by Stinger on Oct 12, 2011 23:42:50 GMT -5
Good question...
Pistons
Oct 25, 2011 14:26:46 GMT -5
Post by ascentpro on Oct 25, 2011 14:26:46 GMT -5
Are your volvo 16v pistons made for press fit or floating pins?
Pistons
Oct 25, 2011 22:42:33 GMT -5
Post by Stinger on Oct 25, 2011 22:42:33 GMT -5
All pistons have floating pins, it's the rods that are either floating or press fit. If using the CP's with press fit rods, you just don't use the pin clips in the pistons.
