Post by 87tbird on Dec 19, 2011 19:42:17 GMT -5
Does anyone know where to find a section of trunk floor, and a bracket that the fuel tank strap bolts to on passenger's side?
Post by warwickben on Dec 20, 2011 6:56:52 GMT -5
Year one mite have it but I know of a place in vt. I'll look it up and get a link more or less if they don't make it you take photos measure and make templates and thell make you the parts.
Post by 72capri on Dec 25, 2011 14:32:39 GMT -5
What kind of car are you working on ?
Post by warwickben on Dec 25, 2011 18:56:41 GMT -5
I was wrong it's not in vt but Canada. www.alfaparts.net/They'll make you any part you need . You can cut out a section and they make a copy from that or you make templates . They explain what they need on there site. Just be smart before you cut a section of your car out and brace your car before you cut.
Post by 87tbird on Jan 15, 2012 18:08:47 GMT -5
Sorry about that, it's an 87 turbocoupe. I think I'll just have to patch it.
Post by warwickben on Jan 24, 2012 12:25:08 GMT -5
Im a metal worker. I don't know how big it is but don't fully weld the seams will cause warping etc if it isn't a load bearing spot.
I patched the toe area of the Capri with street sign the rest of the car will rust out first lol. Use weld thru primer stitch weld then paint and seam seal it and u should be fine. If u have to form it carve it out of wood and beat the metal around it.
