Post by real merkur 87 on Mar 15, 2012 9:31:04 GMT -5
Hello i was wondering is your header any thing like the header from bo-port racing? How strong is it? Is those one like the one on ebay.pls let me know thanks.
Post by real merkur 87 on Mar 15, 2012 9:42:29 GMT -5
Hello stinger: i purchased some 60lbs. Injectors from you. I never used them because im waiting on my pimp i think i need 75's to make over 400rwhp. Would u trade me out some i would pay the difference if any. Never been installed. Thanks
Post by Stinger on Mar 15, 2012 15:08:48 GMT -5
Bo's headers are made from thick wall cast elbows, ours are made like traditional headers with thin wall tubing. That's why there is such a large price difference. The eBay center mount headers are chinese "copies" of my header. They are similar in construction but not equal overall. Ours have beefed up welds, additional bracing, cleaner ports & collector areas, among other things.
As for the injectors, we don't have any 75's in stock right now so you'd either need to go with 80's or 85's. We have a 15% restock/return policy and of course you'd pay shipping both ways.
Post by real merkur 87 on Mar 21, 2012 21:52:19 GMT -5
Hello stinger how much hp does your header produce? Do u have any 75lbs. injectors yet and if not when will u get them? Do want 2 trade the 60s for the 75"s. Do u have any picture on how 2 plum the wastegate tube 2 the exhaust? This is new 2 me and i dont know how its done.
Post by warwickben on Mar 22, 2012 11:12:36 GMT -5
90 elbow off the flang. Flex pipe the a section of straight pipe to the down pipe drill hole and weld pipe to it. If u have a drill press find a metal hole saw to fish mouth the string pipe to better mate to the down pipe .or u can grind it .
Im running a divorced waste-gate that exits out the side of the car in front of the rear wheel...still useing a flex pipe...
I also section the down pipe after the elbow to put a flex pipe in there.
Post by real merkur 87 on Mar 23, 2012 13:10:41 GMT -5
Thank for the picture! its a bit small do have different angles so i can get a better look? Thanks.
Post by warwickben on Mar 23, 2012 19:50:21 GMT -5
I don't got any with the waste gate plumbed in . I'm running a divorced setup that exits out the side. Trying to track down a mini muffle like older 911's turbos used to do.
Post by warwickben on Mar 23, 2012 19:51:14 GMT -5
Can't upload more then one on iPhone
Post by warwickben on Mar 23, 2012 19:52:11 GMT -5
dans
Post by dans on Mar 24, 2012 12:26:34 GMT -5
Nice work on containing the heat!
Post by warwickben on Mar 25, 2012 16:58:45 GMT -5
Yeah when I got a chance I'll take better pics of my wastegate piping, also wraped. All 316 ss . We also putting stick on heat shielding on the fire wall and under the car. (I've burnt girls legs in my rotary cars lol) We went with a weird v mount setup so the rad still gets good air flow. And room for a front mount oil cooler. Intercooler spray bar. Brake ducts. I think well have a problem of over cooling ...
Not sure if you where mocking or not lol.
Post by real merkur 87 on Apr 3, 2012 19:38:33 GMT -5
Hello stinger do u have any headers in stock? Thats the center mount and how strong r they do u have many problems with them if any?
cole50
Post by cole50 on Apr 3, 2012 21:56:51 GMT -5
Hello stinger do u have any headers in stock? Thats the center mount and how strong r they do u have many problems with them if any ? I too would like to know if you have any headers in stock?
Post by Stinger on Apr 3, 2012 22:18:43 GMT -5
Two headers in stock currently.
Post by real merkur 87 on Jun 25, 2012 18:48:20 GMT -5
Hello stinger i was installing the center mount on my merkur and the external wastegate. I was wondering if u have to remove the a/c to mount the wastegate on or if the a/c lines are to close to header runner? One question, have you ever installed a dump tube on a merkur not much space maybe also does the a/c have to be removed for this install? what do i need to do to keep the a/c???
