Post by Stinger on Jun 25, 2012 19:58:21 GMT -5
I don't have a definitive answer since there are multiple different stock a/c compressor and line configurations on 2.3T engines/cars. If the lines aren't touching the header, they are fine (if they are steel). If they are rubber, you need at least 1/2" clearance and it wouldn't hurt to put some foil heat shield on it.
Post by real merkur 87 on Jun 25, 2012 20:14:20 GMT -5
hello its me again do u think i need a stock location header 2 keep my a/c
Post by Stinger on Jun 25, 2012 21:04:00 GMT -5
It shouldn't be necessary.
Post by real merkur 87 on Jun 27, 2012 21:17:24 GMT -5
Hello stinger i have been doing some thinking and i dont think this header is going 2 work out for me. I would like 2 send it back. Its just i dont want 2 lose my a/c and the dumb plumming is very very difficult. Theres no room like the mustang. It hasnt beenstarted up or anything just bolted up. I waited a month or 2 for this and its not going to work 4 me.
Post by Stinger on Jun 27, 2012 23:09:53 GMT -5
There is a 15% restocking fee on returns. If you're ok with that, and the gasket is still intact and the hardware is all there, a return can be done.
Post by real merkur 87 on Jun 28, 2012 10:05:31 GMT -5
Hello 15% is ok. I didnt see any hardware with this header. I went to ace hardware and bought bolts. Maybe i didnt check the box good but i didnt see any hardware. I was going to ask you about that. I will check again thanks!
Post by Stinger on Jun 28, 2012 12:14:14 GMT -5
There is hardware, it's the 4 bolts for the turbo flange, wastegate bolts/nuts, and washers for both. They were in the gasket bag when it left here.
Post by real merkur 87 on Jul 10, 2012 9:26:19 GMT -5
Hello stinger I sent the header back. Do u know when a refund will b issued? Thanks
Post by Stinger on Jul 10, 2012 13:37:51 GMT -5
It showed up yesterday afternoon and the refund is being processed today.
Post by jnielsen on Jul 14, 2012 18:29:02 GMT -5
Does anybody know the size and type of bolts I need for stingers header?
Post by real merkur 87 on Jul 15, 2012 12:01:12 GMT -5
if ur using stock location down pipe do u still use the flex pipe on dump tube and down pipe? Thanks
fess40
Post by fess40 on Jul 16, 2012 16:43:02 GMT -5
I used 10mm header bolts from Stage 8. Got them from Summit.
Sent from my DROID RAZR using ProBoards
Post by Stinger on Jul 17, 2012 0:36:19 GMT -5
if ur using stock location down pipe do u still use the flex pipe on dump tube and down pipe? Thanks If you're using a stock location downpipe then you don't have a Stinger Header which means the question isn't applicable to this thread and the answer would be dependent on the instructions from the manufacturer or your stock location manifold/header.
