Post by fordtech86 on Apr 30, 2012 20:48:29 GMT -5
I have a few spare parts im not going to use any time soon so here goes. Garrett t4 turbo, measured the wheels and it comes out to be a 57 trim compressor in a .60 ar housing, a 76(stage3) trim turbine in a 1.32 ar split entry turbine housing. Has not been bolted onto a car since it was rebuilt by garrett/allied signal. asking 350 plus shipping cheap ebay header and wastegate. Wastegate tube will need to be re-welded. 75 plus shipping Stinger downpipe for center mount header. 75 plus shipping 35lb injectors that where taken out of my tc when i swapped to the 80's. 50 plus shipping Stinger oil return line and flange for center mount header. 30 plus shipping Located in north Ga.
Post by fordtech86 on Apr 30, 2012 20:54:47 GMT -5
turbo
Post by fordtech86 on Apr 30, 2012 20:55:30 GMT -5
turbo
Post by fordtech86 on Apr 30, 2012 20:56:11 GMT -5
turbo
Post by fordtech86 on Apr 30, 2012 20:57:19 GMT -5
Post by fordtech86 on Apr 30, 2012 20:58:14 GMT -5
downpipe
Post by fordtech86 on Apr 30, 2012 20:59:08 GMT -5
oil return line
Post by fordtech86 on Apr 30, 2012 21:00:51 GMT -5
injectors
Post by coreydaniel on May 18, 2012 13:45:15 GMT -5
you still have any of these items?
Post by fordtech86 on May 18, 2012 14:02:31 GMT -5
yes I do.
Post by 72capri on May 19, 2012 11:14:52 GMT -5
All those #'s don't mean much to me. What hp level would this turbo be good for and what rpm would it reach full boost? How does a down pipe attach to it ?
Post by fordtech86 on May 19, 2012 17:23:55 GMT -5
Compressor will support around 450hp, spool would depend on the rest of your set up, not sure about downpipe with current turbine housing(It was originally meant for a diesel truck of some sort). It has a t4 flange so it wont bolt up to the stock manifold, but it has the stage 3 turbine wheel commonly used on hybrids. My plan was to purchase a t3 stage 3(76 trim) turbine housing(.48 or .63) from ATP turbo(or wait on one to pop up on ebay) with the ford 5 bolt flange and bolt it right up, but money is tight right now.
Post by 72capri on May 19, 2012 19:48:24 GMT -5
I am very interested but let me check on that turbine housing.
Post by fordtech86 on May 19, 2012 20:01:31 GMT -5
Im thinking its about 230 from atp but ive seen them on ebay for cheaper. Im not sure but it may be possible to have a factory(stage 1) t3 housing machined for the stage 3 wheel.
Post by 72capri on May 21, 2012 18:10:12 GMT -5
Checked on the housing...it's $250 plus shipping.
