Post by blvdcruiser on Jun 20, 2012 21:05:45 GMT -5
im having trouble figuring out how to install the drain line on my set up (stinger centermount stinger oildrain).. i have a turbo block and one of the 45 fittings is in the threaded drain port. its pointing away from the block toward the pass fender. the hose had a 90 and a straight side. whats side goes to the block and what side goes to the turbo.. were does the hose pass up through the header? between what runners? does anyone have pics?
Post by blvdcruiser on Jun 20, 2012 21:34:29 GMT -5
nvm.... i combed this forum and found pics.. should of exhausted the search before posting
the block fitting points up the 90 one the hose goes on that and the hose runs toward the front of the car.. then up between runners 1 and 2
