Post by SLO FRD on Jun 24, 2012 19:17:49 GMT -5
Ok well i I installed a holset h1c with the 12cm rear and the 8blade front housing and the turbo is sitting too close to the plug wires and it ruined #3 and starting to burn #2....I bought the DEI heat boots from azone but still burnt #3.... anybody else have this problem? and what was the solution?
Post by Stinger on Jun 24, 2012 19:51:46 GMT -5
I just pull them tight against the valve cover and use heat boot covers on the SVO. For more protection, you can put angled boots on #1 and #3 and still use heat boot covers.
Post by bobbarker on Jun 27, 2012 8:26:15 GMT -5
Same thing I did, I burned wires a few times and finally put heat covers on them and pulled the slack tight against the valve cover like Stinger said. Been several months and no issues yet.
