yezzir
Boosting 10 psi
Post by yezzir on Mar 25, 2009 6:50:01 GMT -5
Anyone running a gasket between the header flange and the head? If so, what kind are you using. I had the header machined flat and was wondering it if it will seal up nicely or should I run a manifold gasket?
Post by Stinger on Mar 25, 2009 11:59:54 GMT -5
There is a gasket supplied with the header. Since you've machined it flat, you should be able to get away with not running a gasket and just putting some high temp rtv, copper seal spray, etc. on the surface and get it to seal.
yezzir
Boosting 10 psi
Post by yezzir on Mar 25, 2009 15:49:40 GMT -5
Stinger, this was bought used, so I don't have the gasket that you're referring to. Can I purchase that gasket from you? I didn't see it listed on your site!?
Post by Stinger on Mar 25, 2009 18:11:16 GMT -5
No, but a stock 2.3T gasket will work.
