Post by 87tbird on Sept 26, 2012 16:44:00 GMT -5
Is there any way to set up the external wastegate you sell onto the EGR hole on the E6 manifold. Could I thread a pipe into the EGR with a flange on the other end to accept the wastegate?
On the out side of the wastegate is the flexible 1.5" pipe you sell a good option to loop back in to the exhaust? Is that even how it works? I'm new to this.
Can I get a 1 bar spring (14.7psig) with the wastegate?
Post by Stinger on Sept 26, 2012 17:27:29 GMT -5
The wastegate needs a 1.5" ID hole. The EGR is 3/4" or so...it's also in a less than ideal location since it would only bleed off exhaust from the #4 exhaust port.
With that said, the stock internal gate works for many people. Only when large turbos are used is it somewhat "mandatory" to go external.
