Post by 93turbolx on Nov 14, 2012 13:23:37 GMT -5
Im new to turbo cars and have purchased a 93 hatch with a 86 turbo coupe swap im wanting to add some bolt ons. My question is with the stinger fmic kit does that come with a blowoff valve or you have to add this or what? And i want to add a full 3 inch exhaust and i guess downpipe?..also? But there are about 4-5 exhaust options. Can i run it without cats? Which exhaust package is basically a full 3 in kit? Sorry if theseare things i should know! Thanks!
Post by Stinger on Nov 14, 2012 14:42:01 GMT -5
The FMIC doesn't come with a blow off valve. The drop down menu on the site allows you to purchase the base kit (no options), add a blow off valve bung (1" pipe to clamp a silicone hose and then attach to a blow off valve), or to add the bung and the silicone hose. Then you can purchase a BOV on the "Universal Parts" section of our site that will attach to the FMIC bov bung and hose. It doesn't come with directions as typically the pictures on the site are all that is needed. If you need more directions, you can put it in the "notes" box during checkout and we'll mark all the pipes. Of course we're always available via email to answer any further questions.
The complete exhaust systems on our site are also configured via the drop down menu. The first Mustang option is just the tubing and muffler from the turbo outlet to the rear bumper, the next Mustang option adds the required amount of torctite clamps, the next Mustang option is a stainless steel tubing upgrade with muffler, the next Mustang option is SS and adds the clamps once again.
Whether you can run without a cat depends on your state's emissions regulations. If you have to do emissions testing, you need one.
If you want to make sure you are getting the correct items prior to processing the order, you can add the items to the cart, then copy and paste the contents of the cart into an email and I can look it over for you.
