Post by joedirt007 on Apr 15, 2009 21:24:55 GMT -5
I swapped a 88 TC with an la3 in my 90 ranger. On the ranger injector harness injector bank 1 is injectors 1 and 4, and on the TC injector bank1 is 1 and 2. Do I need to wire the injectors like the TC or leave the way the ranger is? Could this cause the injectors to leak?
Post by Stinger on Apr 16, 2009 1:33:53 GMT -5
I'm not an expert on Ranger swaps but I wouldn't think it would matter which injectors are on which injector driver. No it won't make them leak.
Post by joedirt007 on Apr 16, 2009 10:31:54 GMT -5
Alright thanks. I think I got ahold of a bad set of injectors then, because I've replaced the o-rings several times, tried another TC fuel rail and checked fuel pressure and fuel return. Is there anything else that could cause them to leak?
Post by Stinger on Apr 19, 2009 22:57:46 GMT -5
They sometimes leak between the body and the plastic case. There are two small (1/8") holes in the plastic body and you will see fuel leak out of there. When this happens, they are junk.
