Post by Spoolin-SVT on Jun 30, 2013 2:16:22 GMT -5
Do you have any experience or know if your downpipe will fit fine with bo's non twin scroll header? Would be using an hx35 with deleted internal waste gate. Thanks
Post by Stinger on Jun 30, 2013 2:48:19 GMT -5
I know a few people have used them, though I don't know if it did/what sort of modifications it required. Since the Holset downpipes don't come with a flange and the flange location is the biggest part in getting good fitment, it should be pretty easy to make it work.
Post by Spoolin-SVT on Jun 30, 2013 3:45:31 GMT -5
Yeah,it shouldnt be too hard to get it to fit if it doesnt. Appreciate the help. One more quick question, I have my repinned harness out of my 93 mustang because it was kind of haggard from the swap. I am wanting to use a pimp before I get it back together. Would you suggest using the original 93 2.3 harness or using a harness that has already been swapped for a 2.3t? I know I would have to atleast rewire it for the distributer correct?
Post by Stinger on Jun 30, 2013 11:26:33 GMT -5
If you want to run the DIS ignition, use a stock harness. If you want to use TFI, you'll need to use a properly "swapped" harness that runs correctly on an LA3 or equivalent.
Post by Spoolin-SVT on Jun 30, 2013 11:27:11 GMT -5
Or would you reccomend waiting for the new detail zone harness?
Post by Spoolin-SVT on Jun 30, 2013 12:15:11 GMT -5
Sorry, did not see that last post before I reposted. I will just swap another harness. Actually do you know if Matt still has any that he's looking to sell? Already swapped ones that is.
Post by Stinger on Jun 30, 2013 14:36:51 GMT -5
Normally Matt modifies the customer harness, he doesn't have harnesses on the shelf.
Post by Spoolin-SVT on Jun 30, 2013 16:01:29 GMT -5
A while back I remember him having a couple extra laying around but as I said that was a while ago. I will have to find a new one . Do you know much about the detail zone harness one coming out?
Post by Stinger on Jun 30, 2013 23:36:54 GMT -5
Should be similarly priced to the current detail zone harness.
Post by Spoolin-SVT on Jul 1, 2013 11:10:31 GMT -5
Do you know if it will be a plug and play for a 91-93 mustang using your pimp?
Post by Stinger on Jul 1, 2013 14:18:47 GMT -5
It will be a "standalone" harness meaning it will work in any vehicle once you hook up the power and ground wires.
