Post by cupton79 on Oct 16, 2013 21:31:45 GMT -5
what is the best way to install this? seems like it would be a pain to remove the turbo with the waste gate tube welded to the down pipe.... would it be better to put studs in the exhaust housing of the turbo for easier removal? or can the header, turbo, down pipe, and waste gate tube be removed all together? just wondering what the best easiest way to install all of this as I am hoping to be able to place my order in the next few weeks if all goes well
lazypig
Mmmm boost
Post by lazypig on Oct 16, 2013 22:41:15 GMT -5
put a flex section in the wastegate tube before it meets the down pipe
Post by Stinger on Oct 16, 2013 23:28:20 GMT -5
Agreed, that's mandatory. Also the 2 wastegate dump tube bolts can be removed in a minute or so, downpipe in a few minutes, turbo in 15 minutes...MUCH faster than the stock location stuff.
Post by cupton79 on Oct 17, 2013 6:27:36 GMT -5
ok thanks for the info! I will definitely be putting the flex pipe in, I have seen what happens when you don't and it isn't pretty!
