Post by turbo91xlt on Nov 24, 2013 13:44:51 GMT -5
I just received my oil feed line from you for my holset he341. When I went to hook up the turbo end of the feed line the 90* fitting isn't correct? The oil hole in the turbo is bigger so the fitting just slips in. What is missing here? Is there supposed to be a fitting that is screwed onto the turbo first then the feed line attaches to that? The thread size in the turbo is the same as that of the 90* fitting that screws into the line if that makes sense.
Post by Stinger on Nov 24, 2013 23:40:37 GMT -5
Sounds like you got the wrong fitting. That sounds like the T3 fitting. The HE351 uses a straight fitting and also a longer line.
Can you send us an email so we can work out the best way to fix the problem? Your project schedule will dictate how we fix the order. Thanks.
lazypig
Mmmm boost
Post by lazypig on Nov 24, 2013 23:40:49 GMT -5
stinger sells a adapter fitting for the feed line to the holset thread size i have one on my holset. its another option when you purchase a feed line
Post by Stinger on Nov 25, 2013 0:41:54 GMT -5
He ordered the correct line/fitting, we just sent the wrong part.
Post by turbo91xlt on Nov 25, 2013 15:59:08 GMT -5
ok thanks.
