Post by logodude on May 18, 2009 20:41:42 GMT -5
I recently replaced the vane in my 85 merkur and now she runs like a whole different car(as in it is better now). but now the new problem is I have no power under boost. It does make boost and I can here the waste gate opening (I think its the waste gate). but no power, all clamps are tight also. any suggestions? thanks in advance.
Post by Stinger on May 19, 2009 11:27:47 GMT -5
Smoke under boost? How much boost? Does it make power and then fall off or never make power under boost? Do a leak test?
Post by logodude on May 19, 2009 16:56:07 GMT -5
the car has always smoked, but I dont know if it because its out of tune or what. but it does smoke under boost. I think it does get some power but very little to none. I already blocked off the bov (and plugged the line) to see if it was letting air by and nothing. I have never owned a turbo car before, can you explain a leak test? I checked all clamps and hosing (not much at all) all check out. thanks
Post by Stinger on May 20, 2009 12:50:00 GMT -5
Post by logodude on May 20, 2009 16:16:35 GMT -5
Ok will do those tests. It smokes under all conditions but more under heavy throttle and boost. Thanks
Post by Stinger on May 20, 2009 17:30:48 GMT -5
The color is VERY important in diagnosing the cause, what color is it? White, Blue, or Black?
Post by logodude on May 20, 2009 18:25:50 GMT -5
blue smoke
Post by Stinger on May 21, 2009 18:05:56 GMT -5
Blue is oil...definitely need to do a compression check.
Post by logodude on May 21, 2009 20:21:38 GMT -5
like I said in the first post it got quite a bit of power when the turbo spooled before, but when I replaced the vane it lost it's power under boost. The old vane was toast (tested it with a vantage for resistance and swept it), but the new one seems be a lot better when not boosting but this new problem is created. Could this be caused by the new vane? but will do a compression check thanks.
jet1
Post by jet1 on May 21, 2009 22:03:03 GMT -5
did you try to clear any codes.
Post by logodude on May 22, 2009 14:36:10 GMT -5
I had the car in the shop and pulled codes. I dont remember what they were but I did clear them
jet1
Post by jet1 on May 25, 2009 18:27:58 GMT -5
check again lateley
Post by Stinger on May 25, 2009 21:21:13 GMT -5
Clearing them doesn't help you. You need to write them down so you can fix what it says is broke. What you did was remove your only "help" in fixing the problem. If you've ran the engine much, you should be able to re-scan the codes (write them down!) and relay them here.
