Post by dannysvo on Mar 8, 2014 3:32:50 GMT -5
I have an 86 SVO, I recently purchased the dual piston blow off and the t coupler, I installed it but the valve never opened no matter what I tried, did I do something wrong? I I bought a 1/4' tee fitting and 2 pieces of vaccum hose so everything would be plugged up properly, I plugged up the valve with a hose that was tee'd off the intake manifold hose, but still no whoosh noise, the valve isn't defective either. help?
Post by Stinger on Mar 8, 2014 11:20:22 GMT -5
Where does the vacuum hose go to on your install?
Post by dannysvo on Mar 8, 2014 12:53:19 GMT -5
Where does the vacuum hose go to on your install? (i used the vacuum that goes from the intake manifold to the fuel pressure regulator)
Post by Stinger on Mar 9, 2014 0:27:07 GMT -5
I don't like "stealing" a signal from such a vital device but it's a valid source. Where did you put the Tee?
I've never seen it happen but are you sure there isn't a piece of silicone in the Tee that is blocking the opening to the 1" outlet? I've seen a few that were partially covered that I had to clean out before shipment.
When you have the BOV removed to check that, push the valve open with your finger to ensure it's not stuck.
Post by dannysvo on Mar 9, 2014 1:43:51 GMT -5
I made it a 3 way split, one connected to the fuel regulator, one connected to the intake manifold and the other on the valve. the tee connects all of them no problem but the valve just doesn't open, I even tried putting the fuel pressure regulator hose directly on the valve just to see if the valve maybe needed more air but to open up and nothing... the valve isn't stuck either, it's so strange cause I've seen tons of people do it similar to this and if works fine.
Post by dannysvo on Mar 9, 2014 1:44:11 GMT -5
I don't like "stealing" a signal from such a vital device but it's a valid source. Where did you put the Tee? I've never seen it happen but are you sure there isn't a piece of silicone in the Tee that is blocking the opening to the 1" outlet? I've seen a few that were partially covered that I had to clean out before shipment. When you have the BOV removed to check that, push the valve open with your finger to ensure it's not stuck. ..
Post by dannysvo on Mar 9, 2014 1:46:34 GMT -5
I don't like "stealing" a signal from such a vital device but it's a valid source. Where did you put the Tee? I've never seen it happen but are you sure there isn't a piece of silicone in the Tee that is blocking the opening to the 1" outlet? I've seen a few that were partially covered that I had to clean out before shipment. When you have the BOV removed to check that, push the valve open with your finger to ensure it's not stuck. I don't see anything, in the tee, the valve pushes open as well, I'm not sure why it's not blowing off
Post by Strangeleak on Mar 9, 2014 6:06:35 GMT -5
The valve that is visible through the vent hole will open under vacuum allowing you to see through them. Does this happen when under vacuum at idle?
Post by Stinger on Mar 9, 2014 10:07:42 GMT -5
Yep, that was going to be my next question if the first valve would push open (which it does).
My next question is how much boost are you running when you let off the throttle and aren't hearing a release?
Post by dannysvo on Mar 9, 2014 12:00:27 GMT -5
The valve that is visible through the vent hole will open under vacuum allowing you to see through them. Does this happen when under vacuum at idle? (honestly I haven't checked to see if the valve opens up under vacuum, I'll check today)
Post by dannysvo on Mar 9, 2014 12:01:55 GMT -5
Yep, that was going to be my next question if the first valve would push open (which it does). My next question is how much boost are you running when you let off the throttle and aren't hearing a release? (I've tried it from 5 psi to 15psi and nothing)
Post by dannysvo on Mar 9, 2014 17:44:16 GMT -5
okay, so I tried it and the valve is stuck, it's not opening.
Post by Strangeleak on Mar 9, 2014 18:42:24 GMT -5
One of the o-rings in the upper valve may have rolled out of it's groove. Caution: the primary spring in the valve is under compression, once you remove the Allen screws hold it together tightly in a controlled area.
Without spring pressure, see if you can slide the inner valve freely inside the upper housing.
Post by dannysvo on Mar 9, 2014 20:20:37 GMT -5
One of the o-rings in the upper valve may have rolled out of it's groove. Caution: the primary spring in the valve is under compression, once you remove the Allen screws hold it together tightly in a controlled area. Without spring pressure, see if you can slide the inner valve freely inside the upper housing. (I removed all the Allen screws, but the valve wont come apart, not even if I try and force it open lol, I was gonna try and open it up with a flat screwdriver but I don't wanna damage it, I'd rather exchange it for a new one, if I can)
Post by Stinger on Mar 9, 2014 21:21:55 GMT -5
Email sent about an exchange.
