jet1
Post by jet1 on May 20, 2009 22:10:06 GMT -5
Car started running rough. When i checked this is what i found. TIming bounce from 26 to roughly 35 with spout in spout out it will be at 10 then dissapear. it willl take a good 10 second befare you can see it again then will appear for less tha a second. vacuum reads 15,13,16,15,13,16 afr bouncces around from 14.7 down to 13 to 15 ran codes and get 26 (from mass air conversion always had) 14,41,42, I also noticed around my head gasket it appears wet and it is not coming from the valve cover. It as if it is seeping through.
Post by jedeller on May 21, 2009 13:38:59 GMT -5
My T-Bird runs rough and rich and I also get the codes 14 and 42. I've replaced the stator and the TFI module which didn't help. I've never noticed my timing bounce around like that but I usually just set it and disconnect the light. I'm going to check to see if mine is doing the same as yours. My vacuum reads a steady 18.
Post by Stinger on May 21, 2009 18:08:50 GMT -5
Do a compression check. Also examine your distributor drive gear for excessive wear.
jet1
Post by jet1 on May 21, 2009 21:59:19 GMT -5
will do. I also noticed a new code today 72 . When i clear codes it seems to run perfect for a little while. Now I am getting a really high idle here and there. It will want to jump to 2000 rpm and stay there. I did however unplug the tps and it droped right down. Is that right? it is set at .94
Post by Stinger on May 25, 2009 21:15:43 GMT -5
Normally the hanging idle is a dirty or malfunctioning IAC valve on the throttle body.
jet1
Post by jet1 on May 31, 2009 9:40:45 GMT -5
Hey everyone, A week ago I posted that my timing mark was bouncing around on this tread. Drove me crazy for two weeks. Created very rich reading, but didnt show it on the plugs. Found #1 plug wire would not hold the plug tight enough last week. Made a world of a difference. Also did a oil change a yesterday and I found it runs a 100% better due to the amount of fuel in the oil from running rich. No more high idle either.
Post by Stinger on May 31, 2009 11:51:26 GMT -5
Good to hear, now fix that blown headgasket.
jet1
Post by jet1 on May 31, 2009 18:14:55 GMT -5
you got it. I will have to wait to next week but, what hd should i use with 350 hp? Also should i replace the head bolts I have probably 3 sets of used ones. Do they reallly stretch?
Post by Stinger on Jun 1, 2009 0:16:36 GMT -5
The tune kills headgaskets, not the hp. I know of multiple individuals who made 400+hp on the stock replacement Felpro 8993 gasket that's only like $10. Detonation kills headgaskets and you've admitted to doing it hundreds of times.
If you have headbolts with 6 point heads, you'll need to replace them as they are "torque to yield" which means they stretch by design and are not re-usable. If they have 12 point heads, you can reuse them. It doesn't hurt to retorque the bolts after the first heat cycle. Just loosen them half a turn and torque them to the stock value again (one at a time and in the same order as the first time).
