Post by bgpickle on May 22, 2009 23:07:09 GMT -5
i am getting my parts together to put a 84 svo motor into a 91 lx, i was looking at the motor in my shop and i noticed that there was no blow off valve. just a vacuum line from the intake to the turbo? no bov? did the stock svo motor use one? i would think so! i don't know that much about this stuff BOV or BPV (which one did ford use and which one part # should i use) do you have any pics? Help!
Post by Stinger on May 25, 2009 21:16:09 GMT -5
No blow off valve on an SVO or any turbo ford.
Post by bgpickle on May 26, 2009 6:12:22 GMT -5
what happens to the boost when you close the throttle blades? i thought all turbo motors had them. my svo has a vaccum line from the turbo side to the intake side and no valve! aren't i losing boost all the time then?
Post by Stinger on May 26, 2009 13:39:46 GMT -5
Not all turbo cars have bov's. The boost stacks up between the turbo and tb when you close the throttle. You aren't "loosing boost" as there is no where for it to go. Technically bov's "lose boost" because it lets it out of the system. You can add a bov or bypass valve if you prefer.
Post by bgpickle on May 27, 2009 17:53:22 GMT -5
my svo has a vaccum line from the turbo side to the intake side before the turbo and no valve! aren't i losing boost all the time then because the boost psi is always bleeding off into the intake? i don't think this is right maybe somebody over the years put a vac. line in the wrong place. i wish i knew how to post a pic to show you.
Post by Strangeleak on May 28, 2009 10:07:08 GMT -5
Post by Stinger on May 29, 2009 1:08:17 GMT -5
my svo has a vaccum line from the turbo side to the intake side before the turbo and no valve! aren't i losing boost all the time then because the boost psi is always bleeding off into the intake? i don't think this is right maybe somebody over the years put a vac. line in the wrong place. i wish i knew how to post a pic to show you. I have no idea what you are saying. Post pictures on photobucket.com and post a link to your photobucket here.
