Post by 93stangnow23t on May 25, 2009 19:57:15 GMT -5
i just this morning bought a 86 turbo coupe for $350 for pix see www.allfordmustangs.com/forums/2-3l-tech/176101-my-1986-thunderbird-turbo-coupe.htmli do have a few questions though i read the write up on the swap but I'm not a big wiring expert thats my brother I'm more of a plug and play guy I'm a little confused how you repine the wiring how do you know the #'s of the pin? also on the other site you can see that i have a few questions about pix if someone could help me their that would be great. Reading the write up he was talking about putting a front mount inter-cooler in i plan on doing this but how do you rotate the turbo? i have more questions but cant think of them at the moment so we will stick with these for now.
Post by Stinger on May 25, 2009 21:29:17 GMT -5
The harness that plugs into the ecu is numbered on the ends. First pin is 1, last pin in row is 20, next row is 21-40, last row is 41-60. You count from either end to get the pin numbers between there.
There are unused vacuum lines on stock cars, I don't see anything "missing".
You loosen the 6 bolts on the back of the compressor housing and turn it, then tighten them back up.
Post by 93stangnow23t on May 25, 2009 21:56:33 GMT -5
were does the vacuum line for the one that has a bolt in it go?
also the write up on repinning is for a 87-88 TC what would i do for 86 do you know of any links
thanx for the info so far.
Post by Stinger on May 26, 2009 13:38:16 GMT -5
It may go nowhere...just somebody without the ability to buy a proper vacuum cap to replace a cracked stock cap.
There is no writeup for 86 ECU's into a 93 Mustang, you either compare the pinouts for both ecu's and make your own directions or you buy an 87-88 TC ecu and air meter and then follow the instructions on our site.
Post by 93stangnow23t on May 26, 2009 15:18:00 GMT -5
would an 87-88 tc ECU work though is my question.
Post by 93stangnow23t on May 26, 2009 16:04:21 GMT -5
what is the best 87-88 ECU i would like to get a manual ECU but one of the Agressive one.
Post by 93stangnow23t on May 26, 2009 16:40:44 GMT -5
this is the computer that im looking at what kind is it? E8DF-12B577-DB
Post by 93stangnow23t on May 26, 2009 20:28:42 GMT -5
Post by denz on May 26, 2009 20:32:04 GMT -5
1988 MERCURY SABLE MULTIFUNCTION MODULE this is what i got when i looked it up most comp should also have a number like la3, and so on.
Post by Stinger on May 29, 2009 1:03:43 GMT -5
would an 87-88 tc ECU work though is my question. Yes, I wouldn't have suggested it if it wouldn't work.
Post by Stinger on May 29, 2009 1:04:38 GMT -5
what is the best 87-88 ECU i would like to get a manual ECU but one of the Agressive one. LA3, LA3, 8UA, LB3...pick your poison, that's all that was available in 87-88. They will all run the same for you.
Post by Stinger on May 29, 2009 1:05:15 GMT -5
this is the computer that im looking at what kind is it? E8DF-12B577-DB No clue, look for the numbers/letters I just posted, not the part number.
Post by 93stangnow23t on May 29, 2009 15:02:48 GMT -5
thanks i apreciate it im looking for a LA3 right now
by the way i wasnt questioning your judgment i am 17 and dont have a ton of money to put into this.
but enough to do the swap and maybe buy one of your front mount intercoolers not for sure yet.
Post by Stinger on May 29, 2009 16:16:56 GMT -5
The LA3 will be the most expensive of the above ecu's simply because it is "famous" for unknown reasons. You'll save money if you find one of the other ecu's instead.
As stated above, you'll need the 87-88 air meter as well...also known as the "large vam". It has an approx. 3" inlet/outlet and the vam for the 86 TC is about 2.5".
Post by 93stangnow23t on May 29, 2009 17:00:10 GMT -5
would you know what injectors i have by chance i heard that i would have to buy 35# injectors since some of the 86's came with 30# ones. if i gave you the vin or what month it was made in.
