400 hp
Jun 5, 2009 6:46:31 GMT -5
Post by denz on Jun 5, 2009 6:46:31 GMT -5
can this turbo handle 400 hp here are the specs.
Air Inlet 4" Compressed Air Outlet 2.5" Bearing Ball Bearing Compressor / Journal Bearing Turbine Turbine Housing Flange Standard T3 Exhaust Outlet 4-bolt, 3" OD Cooling Oil and Water Cooled Compressor .70 A/R Turbine .63 A/R Compressor Wheel 61.3 /82 mm Turbine Wheel 62 /67.8 mm
400 hp
Jun 6, 2009 0:29:44 GMT -5
Post by Stinger on Jun 6, 2009 0:29:44 GMT -5
Sounds like a chinese turbo from ebay? New for less than $250? If you answer yes to either of those questions, it's junk.
