Post by 84mustang on Nov 3, 2014 23:13:03 GMT -5
Is a 46 going to restrict the header?
Post by Stinger on Nov 4, 2014 1:04:02 GMT -5
No, not if it's built right with the same exhaust side as a 50 trim (stage 3).
Post by 84mustang on Nov 5, 2014 0:41:06 GMT -5
OK so my build plan is to, and please tell me if you see a flaw in my plan so I can correct it. Its to get my head portend and polished professionally, get a fmic from you, my intake upper is already gutted and polished and lower is knife edged ported and polished, install the header and down pipe and get the 46 trim turbo installed and eventually get a pimp. Is any of that not going to work well together? Is the turbo going to be to small for the air flow?
Post by 84mustang on Nov 5, 2014 0:42:11 GMT -5
is the turbo going to restrict it with those mods? Or what turbo would you recommend with that setup?
Post by Stinger on Nov 5, 2014 1:58:42 GMT -5
What about the cam?
Post by 84mustang on Nov 5, 2014 23:36:45 GMT -5
Well I kinda do want to one day buy the esslinger aluminum head that comes loaded but until then I was gunna stay stock just because I dont know much about after market cams. From what I read it just seems to me like your sacrificing power in one rpm range to gain in another and I dont really want to have no bottom end at all lol I mean its a four banger it already has no bottom end
Post by Stinger on Nov 6, 2014 0:00:29 GMT -5
The 46 trim is a pretty good match to the setup listed above. If you add a good cam or an Essy head/cam package, you'll need quite a bit more turbo as a cam could be worth 50+hp and a head/cam could be worth nearly 100hp.
Post by 84mustang on Nov 7, 2014 9:58:41 GMT -5
So with the above setup with the port and polish of the head what cam would you recommend for a street car? And mabey once or twice a year to the strip?
Post by Stinger on Nov 7, 2014 12:14:49 GMT -5
Esslinger 2277, Boport 1.5 or 2.1 or 2.5, Engle Hot Pinto cam.
Post by 84mustang on Nov 7, 2014 22:12:30 GMT -5
And any of those will work on a factory head with a port and polish as long as I get the springs to go with correct?
Post by Stinger on Nov 8, 2014 1:18:02 GMT -5
No, you need less than ~.450" lift to not require machine work to the head. The 1.5 fits, I can't remember the lift on the Engle cam, the rest are over that mark.
