Post by nmanville on Jun 21, 2009 20:05:13 GMT -5
I was just wandering how this kit fits together? I have a 1993 convertible and I am having a little trouble fitting the tubes together. Does anyone have any pictures or insite? Thanks
Post by Stinger on Jun 21, 2009 23:50:50 GMT -5
L shaped pipe goes from turbo to under the passenger side frame rail. The long straight section goes to the turbo, bend at the other end goes under the frame rail. Then the smaller of the U shaped bends goes from that pipe to the intercooler inlet. The longer of the two legs of the U goes to the intercooler. On the driver's side, the long pipe goes from throttle body to driver's side near the lower radiator hose. Then the remaining U bend goes from there to the intercooler outlet. The shorter leg goes to the intercooler, long leg to the pipe to throttle body.
Post by nmanville on Jun 22, 2009 0:11:46 GMT -5
Thanks, I really needed that
Post by nmanville on Jun 22, 2009 0:53:26 GMT -5
Will this fit right with the stock 2.3l fan and radiator hoses?
Post by Stinger on Jun 22, 2009 13:37:13 GMT -5
Yes, it is designed around those items, though the lower radiator hose sometimes rides on the tubing a bit if the hose is old and sags.
