Post by 93turbopony on Jun 27, 2009 15:42:35 GMT -5
got the car running it was the timing, but is is running crazy rich blowing black smoke, not making any boost, and it blows the intercooler piping off. got any ideas on how to tune this so it runs right, or at lest lean it out. it seams like the injectors are spraying somewhat all the time. Also on my map sensor where does the vac line for it go it is just open to the air and i think that is a major factor but i dont know where to run the line to
Post by Stinger on Jun 28, 2009 12:06:55 GMT -5
Map line is removed from map and the line itself is plugged so it doesn't create a vacuum leak.
What is the fuel pressure?
Post by 93turbopony on Jun 28, 2009 12:23:13 GMT -5
fuel pressure is around 30-35, it seems like an injector is spraying all the time, is there any way i can test them.
Post by 93turbopony on Jun 28, 2009 13:24:32 GMT -5
also when it just starts to get into boost it just baffles and back fires.
Post by Stinger on Jun 28, 2009 22:39:56 GMT -5
Did you scan for codes? Is the cam timing and ignition timing correct?
Post by 79turbostang on Jul 13, 2009 22:36:04 GMT -5
i might sound stupid saying this but check to see if you have the right ecm for that motor... i just had the same thing happen to me i was blowing black some couldn't build boost and the engine wouldn't tack over 35 hundred RPM and would back fire
